1 - 20 of 28 Posts
They arrived on Saturday, I had to wait til today to ride one, they have to have more than 25 miles on them before the Riders Edge bikes can be rode.
FYI I am riding this before all the drop protection is on it, and before the rev limiter on first through third is flashed into it.
I am riding it at 4750 ASL, so this will derate the horsepower to 0.94. So 33.5 times 0.94 to reach approx. 31.5 HP.
I was riding in 72 F weather so no derate for temp.
I am 5'6" and 169 Pounds.
These are my opinions, they are always correct. If you have a different opinion then yours is correct for you, mine are always correct for me.
The bike is small. Sits on a 1982 GS1100 Kick Stand as far as I can tell. And the kick stand is switched so it must be up to go into gear.
My dealer turns me loose on bikes I want to ride because he knows my interest is the design function of the bike, not tearing up the equipment.
I tossed my Cor Tech Magnetic on the tank and started the ride.
For me the riding in the beginning is a lot of parking lot work just to see what the engineers did and did not do.
First I check the rear wheel to front wheel tracking in the slow tight turn radius. There is about a 12 percent crabbing of the rear tire in the tight turn lean. This bike goes over further than any Harley I have ridden. (Never been on a street Rod but I hear they go over well too, my VRSCA does not I am always dragging radiator shrouds)
Then the lock to lock turn. This is one of the few mistakes I found in the engineering. The steering turn locks allow for the bike to go over the trail and contact patch creating a situation where a low speed a tight turn will want to through the bike to the ground on the forward axle axis. This can be fixed it desired by adding in 5/8 of an inch to each turn stop.
Turn at speed, at 12 miles per hour the bike can do a 34 foot turn leaned over pretty far. Switching direction of the 12 MPH turn requires 14 feet for a comfortable figure 8 with no tear drop shape to it. (this indicates a gear dragging turn should be about 28 feet, but I am a pussyy so I did not push it to chicken strips of the tires)
Low speed control is very nice, all slow speed maneuvers I performed are with the clutch plates closed up. I do not play in friction zones except start and stop. The rest of my riding is clutch open clutch closed. The loops and figure eights are easily performed with a completely closed clutch. The tightest turns possible do require one to sit more on the higher elevated part of the seat (the side edge of the seat pointed towards the sky in the turn) for best response, failure to reposition does cause a slightly large circle. There is a torque fight bucking at 0.5 MPH when really letting it lug. No one rides in this range, but I wanted to know.
Panic stops are excellent from 45 MPH to O. Not much more than 25 feet on average. When I was doing them I locked the back up twice, this did add 3 feet to the stopping distance. I do lean up on the handle bars when performing a panic stop distance test. So sometimes I get a lot of weight off the rear wheel which is why I think it locked a couple times.
Twisty performance is very good. Lean angle is real good. Please don't respond that your Ducati can take it, it makes you look very stupid. The point is the bike drives very nice in S turns and sweepers, two closing radius turns were tested, excellent machine for these turns. While many push forward on the inner bar, I am a push the inner while curling the wrist up on the outer bar lifting it. The bike will drop right into the new radius with no problem. The bike did allow me to scrape a knee in one of the tighter turns. Though this is due to my flopping the inside knee towards the curbing and riding the outside knee up to the tank line on purpose.
Acceleration is fantastic to 55 MPH. No problem playing in traffic, no problem catching up or passing.
Highway speed.... Acceleration from 55 MPH to 70 MPH is very acceptable, however, 70 to the 87 MPH limit it had with me on it is very slow. 75 MPH is hit fairly easily, but from there above is a crap shoot. Grade and wind play with the 31 HP available and it shows. That said we are talking about a 31 HP machine. So it is what it is, two hour trip, probably OK, 4 I don't think so at highway speeds. I do not think the 750 will be a problem in this area.
Shocks and forks, I took some of the biggest gulley washer dips I know of, never bottomed out and never tried to launch me.
I think they have got something here, I can see these buzzing around town and what not. I can see these being used as a learner bike easy. I can see the 750 as a daily driver and weekender bike pretty easy too.
My ride was 24 miles. I like the thing, but then I bought one so my opinion started the ride as positive.
I will answer questions if I can///
Is this the bike you bought?
Cool looking but 500cc 31Hp......seems a bit anemic for highway riding but I guess they aren't designed for the long haul. What is the Tq rating?
No I have the 750 on order. This is a riders edge bike that came in. Same frame different power plant.
Sent from Motorcycle.com Free App
I was looking at the 750 the local dealer just got in, no test rides, dealer just showing it off. What I like is the radial tires knowing that will give me the road holding handling I want. I get harassed by my HD friends cause I ride Japanese bikes, but I want handling and water cooling and this is the ONLY HD that impresses me. + NO CHROME! I hate Chrome!
Very serious question? Will I get respect from other HD Owners for owning this bike or will they cut it down saying it makes HD look bad?
Very serious answer. I don't know nor do I care if it does or not. I buy what I like. Stay with the Yamaha you own or not.
The Best Me I Can Be
Well balanced, high quality people will be fine. Idiots and jerks will give you grief.
We went through this already with FXRs.
I rode a 500 the other day. I thought it was great. Quiet and smooth and it challenges you to use the relatively small amount of power. Harley could do a lot with the platform with forward controls and different bars.
Looks good too.
I also saw a Bolt, which is a Yamaha - I think - imitation of a Harley. It looks like a cheap imitation of a Harley.
There's always a smart ass in every crowd who really cares.
People used to give me crap for riding a Shovel for 19 years now
it's a "cool" bike..... Go figure.
Looks good too.
How did it shift. With the lower power, a smooth shifting trans could make a big difference.
You'll get grief on anything you ride HD that's not the most popular HD going at that moment or at least 30-40 years old. Anything new, water-cooled, fast or looking and sounding different will get them going. I believe, in another post somebody called them "purists"?
:coffee:
Do you think my Vegas ever will?
:whistle:
No.
:coffee:
Or...The people who kept the MoCo afloat in the most dire of Years...
None the less...I am glad the newer...smaller [even if they have to be watercooled] H-D's are available...
I have noticed that in the last 20 years, alot more "old timers", "faithfull" and "purists" have .....Developed!=devil=
The entire demographic has changed in the last 20 years so how have they developed or is that how they developed?
30 years ago people used to ask me why I bought junk referring to my Harley today they really don't even give it a second look they're so common.
The demographic has changed dramatically. Yet, the multitude of attitudes, good and bad, stay the same. This dynamic is surely a case study. Not so much, the dynamics, but the blind eye to it. Ya know, it's always the other guy that's posing.
And yes, Evo's, HD's, are as common as smashed taxi's in New York city. It's nothing rare or unusual anymore, nothing special to own one anymore. Who doesn't or hasn't owned one? They are vanilla, milk toast by most standards.
Whenever I see my accountant neighbor leave the house on his sled, 2-3 times a year, dressed like Captain Ahab, I think, damn, somebody's gonna get a nice low mileage, well polished, scoot someday - and cheap!
No.
That they did. Very true. It's a double edged sword, however. Kept them afloat by demanding and/or supporting ancient technology. Paying to much for it and allowing HD to rape their wallets with high service costs and accessories.
1 - 20 of 28 Posts
