I have a 2005 Duece with a stock drive belt.
What maintenance do the belts require, adjustment, cleaning or anything ells?
"Jane you ignorant slut!"
The adjustment settings are in the owners manual. If you don't have one, buy the service manual, then you have everything else too. It does take a special small tool to push the belt to ten lbs. It's cheap at the dealership. You don't want it too tight, or too loose as these belts are expensive to replace.
If it starts to chirp, take a bar of soap and rub it over the edges. Otherwise it's maintence free. Ride it.
Have the tech eyeball it next time you get a rear tire.
