1 - 12 of 12 Posts
Have the Rineharts on my 05 Classic , great sound and looks, but you will lose some low end torque as with all true duels.
Something you may want to consider when selecting pips is if your going to add a device such as a PCIII or Thundermax to richen up the fuel mixture as the stage one flash the stealer will sell you will still be to lean. They have custom maps for cretin pips listed on there websites.
http://www.powercommander.com/807-311.shtml
http://www.zippersperformance.com/catalogue/showproduct.asp?cat=588&prod=1415
Infidel
Dave1200C said:
My friend likes the Rienhart True Duels
I have Rinehart trueduals on my 02 RK with a JIMS 120 in motor. The JIMS motor really breathes hard and those Rineharts rumble at idle and roar when I twist the wick.
Be advised there are 3 types of baffles:
2" - so-called quiet baffles - will help with low end torque loss
2.25" baffles - come stock with the pipes
2.5" baffles - must be for increased sound, high end HP???
Bub has a dynosheet on their website.
Use the pulldown menu to select "Harley Rinehart Page"
The link to the dyno sheet is right after the pic of Rineharts on a bagger.
Good Luck!
I do not know which kind of mufflers you are going to buy, but one thing is for sure: do not buy Screamin' Eagle Performance Mufflers (jump to archive and find my post NEVER buy Screamin' Eagle Performance Mufflers! NEVER!).
So, if you change just mufflers, you do not need to adjust EFI (fulel), but definitely it is better to do that.
But if you add performance air cleaner side by side with your performance muffs, you need to adjust your EFI, that is a MUST!
Go with RevTech DFO. I have read hundreds of posts and have asked the number of questions and I found out that the DFO is better idea than Power Commander. Expensive SERT (Screamin' Eagle Race Tuner) is designed for serious upgrades.
Hope this helps, but also wait for comments from other guys!
Best
emirharley
"Sarajevo Bikers Club" MC
www.sarajevobikersclub.ba
2001 Harley-Davidson Road King Classic FLHRCI HDI EFI
Screamin' Eagle Stage One Kit
RevTech DFO Stealth Performance System
(Set two: Wild Pig Pipes, 2" baffles)
Ape Hanger
Back Rest
Kuryakyn Spider Light
et cetera
Infidel
Dave1200C said:
If I just change the mufflers do I have to adjust my fuel??
No.
But it's like being half pregnant.
A free flow air breather + less restrictive pipes = Stage I. But you will need the Stage I reflash (EFI) or some way to correct the lean condition you will have.
StageI is the most cost effective performance mods you can do.
It is so common that it is referred to a payin' the harley tax. :laugh:
wyodude said:
No.
But it's like being half pregnant.:
Good, very good.................:thumbsup:
emirharley
Ape Hanger
Back Rest
et cetera
This is like asking "what color should i paint my walls?". Since it's being discussed.. I have Porker Pipes and with the right baffles.. they sound good to me. :)
Just a kid at heart
I just installed a set of S&S Stainless Ovals and I like them, not too loud, nice deep rumble. Haven't dyno'd them yet but the bike seems to run pretty well with them.
Here's the advice I always give to someone asking about pipes. Go hang around a biker hangout; coffee shop, bike shop, bar, etc and listen to the bikes coming in. When you hear one you like, check it out, find out what it is.
1 - 12 of 12 Posts
