91 xlh883 the flange will not fit against the head creating a leak small high pitched popping sound . What can I do about it ? Is it the flange that is the problem or worse ?
If the gaskets are good then loosen up the rest of the exhaust brackets behind the head pipes and tighten the nuts on the exhaust studs on the head.After that tighten the exhaust brackets starting from the front and work rearward.Make sure the exhaust isn't in a bind when tightening things up.
