Ok, you guys have really got me concerned, I have a 94 Fatboy, it has 35 miles on it. I modified it when it was brand new. Heads flowed, S+S carb and manifold, Rev. Tech Cam and pipes, adjustable push rods, Excel ignition. The thing runs beautifully but has tappet noise at idle. Doesn't use a drop of oil. Compression check is 125 lbs. on both cylinders.
I don't recall if I changed the Stock Cam bearing or lifters, but chances are I didn't or I think I would recall it. (Getting Old)
My question is; Am I living on borrowed time in regard to the Cam bearings? Would you recommend replaceing, immediately? If so should I replace bearings, lifters, cam, and pushrods as they all have worn together? I would rather be safe than sorry and have lots of winter time to kill.
