1 - 20 of 26 Posts
I have a FXLR Custom Low Rider with the EVO engine.
The bike has ran great for me but about a month ago I noticed
a vibration when in 5 gear and running at 50 to 60 mph
The bike has always had a light vibration at 2000 rpm but never at 2800/3000 rpm
Just for input all mounting rubber is new as of last year that includes
new Progressive rear shocks and front springs.
The bike starts and runs nice and all works well.
I would like input on what possibly could cause the problem.
I did take the bike to the local Harley Dealer and the service Mgr rode the bike
and said "Yep she vibrates starting at 50 to 60 MPH"
But they did not have an answer as to what was cousing the vibration.
Thanks for any help.
Has the vibration gotten progressively worse? Or was there a sudden on set of vibration at 2800/3000 rpm?
Is the vibration associated with a particular speed or with a particular rpm?
That is do you have the same vibration at 2800/3000 rpm in 4th gear as you do at 2800/3000 rpm in 5th gear? Or do you notice the vibration at 50 to 60 mph regardless to the gear you are in? Does the vibration abate when you pull in the clutch?
Have you checked the tightness of all the engine mount fasteners?
Does the bike track straight?
Do you have spoked or cast wheels? Any loose spokes? Any damage to the wheel?
Lost any wheel balance weights?
Where do you notice the vibration? (handlebars, seat, foot peg, etc)
Are all the exhaust pipes properly aligned with the fasteners tightened? Any interference with the exhaust system and the frame of the bike?
To 84 FXRP
ANSWER: THE VIB JUST STARTED LIKE ALL AT ONCE
ANSWER: THE VIB IS MUCH STRONGER AT 55 MPH IN 5TH GEAR
YES WHEN I PUT IN THE CLUTCH THE VIB STOPS
ANSWER: THE FRONT IS NEW/RUBBER MOUNT THE REAR DONT KNOW
ANSWER: YES
ANSWER: FRONT SPOKE REAR CAST
ANSWER: NO
ANSWER: FOOT PEGS AND HANDLEBARS THE SEAT I DONT NOTICE
ANSWER: THE EXHAUST IS IN FINE SHAPE ALL ALINGNED AND TIGHT NO INTERFERANCE.
ONE LAST BIT OF INFO THE VIBRATION STARTED ABOUT THE SAME TIME MY TRANNY WAS OVER FULLED
TO THE POINT THAT LUBE WAS COMING OUT THE SPLIT HALF. ALL LUBE WAS DRAINED AND FILLED
TO THE PROPER LEVEL. DONT KNOW HOW THAT COULD CAUSE THE PROBLEM.
To 84 FXRP
84FXRP: Indicates that it isn't something that just wore out.
84FXRP: Indicates that it isn't wheels or tires.
New Question ----> 84FXRP: Have you inspected the slack on the primary chain?
84FXRP: You might check the fasteners on the engine mount and engine to transmission anyway. It is possible that a bolt has loosened. The top motor mount is under the tank.
ANSWER: YES
84FXRP: Indicates it is not an alignment problem.
84FXRP: Given your earlier response it does not seem like it is a wheel.
ANSWER: NO
84 FXRP: Check
84FXRP: Check
84FXRP: Check
It is interesting that the vibration is associated with 5th gear at 2800/3000 rpm but not 4th gear and the same rpm, and the initial onset with the tranny overfill. The 5th gear, but not 4th gear, aspect of the problem would seem to point towards the transmission. Although, I agree with you, that it is difficult to see how that would have caused the problem.
Can you duplicate the vibration at ANY engine speed in 4th gear?
Sorry, not much help.
Answer: The slack is to spec but I don't know how much it is worm
I do believe the vib is getting worse (hard to tell) when the vib
starts at 50 mph one can here just a slight bumble or howl
it is hard to tell with the wind but I can here a change in the sound of the
bike
Looking at things...if it was a bearing or shaft the vib would be there all times
and for sure as the rpm/speed goes up but that is not the case.
It must be some type of harmonic that becomes active at the 2600/2800 rpm
right? I have check everything that I can think of outside of the bike
Discussion Starter #6
OK new info
#1 the vib is in every gear
#2 the lower gears do not have as much vib
because one goes through the vib rpm fast
#3 5th gear has the most vib
#4 The vib is strongest in 5th gear with a load
#5 The vib starts at 2500 and is gone at 3000 and on up
We have a 30 mph wind with gust to 45 up here today so it is a little
hard to pick up any noise.
Again the vib seams to be in the front more then the back
The foot pegs handlebars and also the fuel tank vib.
so it could be the engine rear mount ?
Twist it, pop it, burn it
Hey 84 - Could the frame be cracked somewhere and getting worse??
Bluesman said:
...Again the vib seams to be in the front more then the back
The rear vibration isolation system is the rubber cleve blocks in the swing arm pivot. These are pretty tough. The bike would seem "squirrelly" in the corners if they were failing.
If the bike always had the vibration issue I would suggest tweeking the top motor mount stabilizer. But given the sudden on set of the vibration issue I don't think that would be the problem.
Sorry I have not been much help, vibration issues are sometimes difficult to isolate.
(FYI - If an FXR tracks straight (properly aligned) and has excessive vibration, ONE POSSIBLE reason is stress on the top motor mount. With the FXR blocked upright - (vertical - NOT resting on it's jiffy stand) remove the fuel tank.
There is a turn-buckle that attaches the top motor mount to the frame. One bolt thru the turnbuckle attaches it to the frame. The other bolt thru the turnbuckle attaches it to the motor mount on the top of the engine.
Loosen and remove the bolt attaching the turnbuckle to the top motor mount. With the motorcycle blocked vertical, start and run the engine for 10-15 seconds.
Stop the engine.
Now, with the motorcycle upright (vertical), the removed bolt (bolt that attaches the turnbuckle to the top engine mount) should just DROP through the turnbuckle and into position on the engine mount. DON'T HAVE ANY SIDE TO SIDE PRESSURE ON THE ENGINE TO GET THE BOLT TO ALIGN.
If the bolt doesn't just "drop" into position, then (keeping the bike vertical) adjust the turn buckle until the bolt just falls into place. Torque fasteners to spec and replace the gas tank.
Sometimes folks don't follow the Service Manual and replace the front motor mount or try to align the bike without removing the top motor mount turnbuckle bolt.
Possible, but Bluesman didn't indicate that the bike rode "funny" in corners. Also he didn't mention any event that might have damaged the frame. FXR frames are pretty substantial but you can always break something.
Discussion Starter #10
To 84FXRP:
Well it looks like you were right about the upper engine mount and turnbuckle.
The turnbuckle bolt to the engine is so tight I can not get it out.
There has to be a great deal of side pressure on the bolt because I gave it a good whack
a few times and it did not move. There is not much room to try to remove it so
I guess the best thing is to take it to the service center for the repair.
I am sure that the problem is when the lower motor mount was replaced they did
not adjust the upper turnbuckle.
Discussion Starter #12
84 FXRP:
Well got the bolt out and the turnbuckle was off 1/4 inch I just came
back from a test ride and 75% of the vibration is gone.
I still have the vib at the 2000 rpm like it was from day one but the
50-60 mph has improved.
I am betting that the lower turnbuckle need to be adjusted as well.
Where did you get the info that you posted ? and does the same
procedure apply for the lower turnbuckle ?
Bluesman said:
84 FXRP:
DON'T MESS WITH THE LOWER TURNBUCKLE IF THE BIKE TRACKS OK!
The lower turnbuckle is used to align the bike. If the bike's alignment is ok DON'T adjust the turnbuckle.
The rubber "donut" on the front motor mount should have equal "squish" all around. The Shop Manual has a procedure for changing/adjusting the centering of the rubber donut.
Problem is that one thing CAN effect another. You could loosen the bolt that runs through the motor mount, lift the engine JUST enough to allow you to center the rubber mount, then retorque the bolt down. This MIGHT cause the alignment to be off.
BTW the alignment is easy to check using a couple of straight edges. I liked to use long florescent lamp tubes.
What got you into this situation is that the mechanic did not remove the top motor mount bolt when the bike was aligned. The Shop Manual requires this bolt be removed while the alignment is obtained, but removing the bolt requires removing the gas tank. The mechanic saved time by not following all the procedures, but the result is a bike that vibrates.
The Shop Manual does not call for idling the engine 15-30 seconds, but this extra step allows the motor to "center itself" as good as it can be. A HD mechanic showed me this procedure in the days LONG before Harleys were popular. LOL
I would check to see if the motor mount rubber isolator seems "centered" in the mount. If it is squished out to one side, then correction is in order. Before you do this be sure to have access to a real HD Service Manual - the manual makes this pretty straight forward.
Discussion Starter #15
84FXRP:
This is a follow up to my Vibe problem. As stated above after adjusting the top stabilizer
most of the vibration went away. So with things seeming to be normal I took of
on a early fall ride of 500 miles. After about 175 miles into the ride the vibration came back
with a vibe from Hell. I canceled the rest of the trip and rode back keeping the
bike in the 70/75 mph range (smoothes out at that speed)
After think about all the things that have been replaced it came to me (with a bang)
that just maybe the stabilized rubber bushing had gone hard .
I check all my records and figured out they had not been replaced
"Never" So I have 2 new stabilizers on order and I believe that may be the problem
because I tried to punch a screwdriver in the side of one and it was like iron.
My question to you is what about rear mounts ? Why nothing is said that the problem
would be there ? As I see it the top mount is just a horizontal stabilizer right ?
What do you think ?
Bluesman said:
84FXRP: ... My question to you is what about rear mounts ? Why nothing is said that the problem
What do you think ?
Bluesman,
You are correct about the need to inspect the rear motor mounts. The service manual has a procedure for checking them.
Another resource is the book "101 Harley-Davidson Performance Projects for Evolution Big Twins and Sportsters" by Kenna Love and Kip Woodring 1998 (ISBN 0-7603-0370-3). Project 29 is about servicing rubber engine mounts (page 93) and has good photographs that accompany the narrative.
On the FXR there are three alignment adjustments.
First, the rear wheel can be misaligned in the rear fork - the distance from the swing arm pivot shaft center to the rear axle center should be the same. Correct by adjusting the chain/belt adjusters.
Second, the powertrain (engine/trans/rear fork/wheel) can be horizontally misaligned with the chassis - the front and rear wheels must line up. Correct by adjusting the front stabilizer to align the rear wheel with the front wheel.
Third, the powertrain can be vertically misaligned with the chassis - powertrain "twisted" relative to the chassis. Correct by adjusting the top stabilizer.
(Note: #3 was what you corrected earlier. The twist in your powertrain resulted in excessive vibrations being transfered from the engine to the chassis.)
Discussion Starter #17
84FXRP
Thanks for the info and your halp. Looks like I will be busy for sometime
but it is a good time to get things done the weather has cooled
Thanks again:wavey:
harley92 said:
just a dumb question does it have the b engine if so you should ck the ballance shaft chains and tentioners
Since you asked and no one answered,not only are FXRs rubber mounted much like the Dynas they are also all Evo motors and there was never an Evo B motor with balancers,balancers are in TC B motors only.
Not only that, Evo's like all Harleys prior to the Twincam 88 have gear drive cams so there are no chains in the engines at all.
Discussion Starter #19
Attn: 84FXRP
The saga goes on...I pulled the front engine stabilizer and the rubber was destroyed all the way to the
locking V in the center of the bushing..One could see that is had been metal to metal
I replaced that stabilized and was sure the problem was fixed " NO"
I replaced the upper stabilized and the old one looked ok and with the new one the vibe was
still there. You had talked about the swing arm and bushing and bearing so
I took the bike to one of my local Harley Dealers. They pulled the side plates and tested the
unit and said all was working fine with no play and the shaft had not froze.
OK what do we know
#1 The bike vibrates at 2500 to 2850 rpm
#2 The vibration just started about 250 miles ago and is getting worse.
#3 The vibration happens in all 5 gears
#6 The vibration will happen if the bike is in a static position
#7 On a smooth road and speed that does not include 2500 -2850 RPM one can not find
a smother Ride once over the 2900 RPM all the way to red line it is smooth
below the 2500 RPM the same just smooth.
Using logic
#7 One can eliminate tires, wheels wheel bearing because the bike vibrates not moving.
#8 One can eliminate the primary chain or the out put belt (same as above)
# 9 Alignment does not come into play because the bike not moving (same as above)
I called Harley Davidson Customer Service Milwaukee for help and the "Lady tech"
came up with "Rod or Flywheel" was the problem and she had a great deal on a rebuild engine.
I find it hard to believe that a bad Rod (rod bearing) was bad it would be bad at all RPM
the same with the flywheel pin.
The thing that bothers me is I have run many search on the web for the same problem and
a lot of riders have the same problem at the same RPM but know one has resolved the problem.
The cash register is running but running out of possibility
OH yes the Harley went over every bolt that bolts the engine and tranny with a torque wrench
and all were within spec or above.
Bluesman said:
Attn: 84FXRP
....OK what do we know
Using logic
#7 ....
# 9 ...
A misadjusted, bad worn, or damaged (tight links) primary chain can be a source of vibration. 2500-2850 rpm may just be the harmonic range.
1 - 20 of 26 Posts
