I'm getting set to install a mild cam in my EVO bagger & thought I had better ask here first to avoid problems later..
First?... Should I just use new Harley 18523-86B lifters or spend the big bucks for some Jims lifters? My red line is 5800 RPMs & no other engine work.
Next?... It looks like the new cam will need an additional spacer washer.. Do I need to use a single thick washer or can I just add another (appx .050") spacer & use the stock thrust washer? When the new cam comes in I will measure it & set end play to about .010"-.015" just asking on the best washer arrangement.
Is it best to use the original cam gear or is it OK to use the gear that comes with the new cam (as long as it measures close to the original using .108" pins)?
Is the stock plastic breather gear good or do I need a steel one?
I am installing a new Jims inner cam bearing..
Anything else I need to look for or look out for?
Thanks........JD
Thanks........JD
