RIDETOEAT said:Any know typical issues with my 88 model.
I believe it did. My 89 FXSTS had that carb on it.newultraclassic said:I don't know whether your 1988 model had the straight side-draft (non-CV) carburetor or not. ...
To add to the list above:There are so many differences from models to years. Just to name a few...
L84-89 mainshafts have a tapper for the clutch basket and a keyway.
90-up had a splined shaft for the clutch basket.
80-86 had the "diamond" end cover and used a clutch arm.
87-up uses the clutch ramps.
FXR and early FLT share the same tranny cases.
The FLT/baggers incorperated the oil tank around 93.
The Dyna did the same and uses a different case as well.
The early FXR/FLT had adapter brackets to mount it to the engine.
Then there are different ratios ... then all that leads up to the Twin Cam transmission case changes that bolt directly to the engine cases. It goes on and on .... I would have to look in the book to determine specific differences from year to year and model to model.
Any evo will bolt in place of another evo.I have been looking into to try and figure it out and I didn't realize how broad of am answer there would be.
I guess the better way to ask is to say " Are the EVO engines cases universal throughout the models. Is an EVO engine out of an FXR or touring able to replace a Dyna or a softail ???
My interchange says 95 to 98 will fit.I'm curious as to how l o n g the H-D DYNA 5-Speed Transmission CASES remained the same ...
I have a 1995 DYNA Convertible with a 5-Speed and am SHOPPING for a REPLACEMENT transmission ... and want to KNOW what YEARS of Transmissions will BOLT in ?
I'm assuming that "ANY" EVO era DYNA transmission "should" FIT (but don't KNOW)
There is a SELLER on eBAY that insists that his 2001 (Twin-Cam) DYNA Transmission will fit my 1995 EVO DYNA ?
Is he "right" ? CORRECT ? Do the TC (Twin-Cam) Trannies remain the same as the Mid-1990's EVO Trannies (at least EXTERNALLY) ?
Please advise (I don't want to PURCHASE & Pay for transportation & then NOT have it FIT)
Thanks in Advance
Coop
How do you upgrade the trap door setup and clutch cable for an 86There are so many differences from models to years. Just to name a few...
