Good morning from the west coast... Sorry for the double post... it's a noob thing.... But I wanted to get the last of this right in my mind before I look into 2 bikes today. My own 06 88 w/14k.... and my bud's 06 88 w/44k. Both are running well.
I've recently logged many hours reading forums and searching the interweb regarding upgrades to my 06 tc88.
First, I wanted to learn about the 'known' tensioner issue. I've read so many posts and articles. It looks to me that there are many cases of good mileage and tolerable wear on these oe spring loaded tensioners. That being said, some say that they can go to pieces, causing severe damage in only a few thousand miles. My sg has 15k now and runs great. I do want to open it up and get a look in there this winter. My current thinking is using the 07 (se?) plate you mention. I was thinking gears, but I have a few thoughts on that set up... 1, for the $, doesn't get you much hp ( 3-5 ? ), and 2- with the possible runout issue, I would worry about grinding up the gears too, as I would have some else set that up. Seems to me that the 07-up plate is reliable with proper maintenance . I have a decent little shop, lots of time, and want to do my own work.
I've also looked at many cams. Looks to me that alot of the ones recommended for the touring 88 are very similar. One thing I do know is that I'm not one to shift much beyond 4500. I'm careful not to lug it, and will shift down when needed. I ride alone for the most part, and we do a fair amount of mountain riding, as you know, here in WA. That being said, I notice that the 37's intake closes at 40, would I be better to find something around 30, since I don't ride high in the revs ? Currently it runs about 2900 at 75, usual freeway speed. I would guess, off hwy, I like to run between 2500 and 3500. One more question on cams... am I correct in that the inner bearing on my 06 is a smaller Dia than the 07-up ? Does my 06 use the torrington bearing OE ? If it is a smaller Dia, then can I assume that a cam for my 06 has 2 different bearing Dia ? One size for the case, and a larger one out front, in the plate ? What are your feelings on the increased pressure 'baisley' type spring ? I think I could go on, but that's enough for now.....
Thanx in advance
Thanx in advance
