Since I already have a stage 1 filter on the carb on fy 99' dyna sport and this system is not hooked up anyways, can I just remove it completely with out any worries??
Does the vent valve on the gas tank need to be plugged if I do remove it??
There are two lines, the tank vent stays open, the line to the carb gets plugged. There will be some spillage from the tank line if you top up the gas and park, so leave that line long. :chopper:
Thanks, I pulled it of, looks better.
Question, the purge line form the carb to the canister was not connected to the carb. Does the black valve fitting on the carb for the pruge line need to be plugged?
I have two lines running up the left frame. The tank vent is open, the "purge" line to the carb is plugged. {I forgot about the "clean air" line on the right side, from the A/C to the canister, its been gone forever}
