After getting everything installed and chest cover torqued per the manual, the cam gear and pinion gear aren't aligned like I think they should be. Stock cam aligns fine with the pinion. The new cam hangs over a little outboard towards the cover. Is this normal?
i second therm,,, end play may be incorrect, i prefer to set it at .010" or as close as the correct shim will allow... dont forget to factor in the dimension of a new, compressed gasket..
a shim kit has every thickness of shim made...
