If any of the Guru’s could help me. I am experiencing a bad stutter at low rpm with popping at the exhaust. It happens from idle to about 3000rpm and then clears.
I feel it the most in second and third gear while cruising at 2500-3000rpm.
Almost feels like the timing is off, but this is a 95” TC.
I put some new plugs and the bike ran good for about5-10miles then started to act up. I pulled the plugs when I got home after about 15-20 miles and the front plug was white with some very light coloring and the rear plug was all black. The rear plug was not wet or oily in any way, just dark and dry.
I switched the plugs around and took it around the block. I pulled the plugs and the rear that was the front had now turned brown in that short trip, and the front plug was starting to clean.
Help……….. What could this be?
