Hopefully I'm posting in the right place. I have an 02 FLHTCUI, Vance & Hines Big Shots Long Part Number 17915, SE Air Cleaner, Stage 1 ECM, and a PC III USB. I installed map 807-178 and trimmed the aft (#1) cylinder to +5%. I also added 20% in the 0% column to reduce decel popping. As advertised, when I turned on the ignition switch, the security light came on and went out after 4 seconds. When I moved the stop/run switch to run, the engine light came on and went out after four seconds, the fuel pump primed………….and then the engine light came on again……and went out after six seconds. I ran the TSSM diagnostics. There were no historical codes, nor were there any current codes. Bike started fine, and ran great. Plenty of power, and just a touch rich like I want. No decel popping. The same thing happened during the next power up.
Any idea why my engine light comes on and goes out a second time?
