I am eliminating the primary chain oiling system on a buddies 76 FLH. According to the book the oil return is a gearcase breather (3/8 hose fitting). There is also a separate crankcase breather. Do you pull this fitting out of the case and plug the hole where the primary oil return goes or just routed this line to the vent Tee to the oil tank vent instead of the primary vent hose. So here's the plan. Plug the return and vent holes in the primary cover, use the oil feed fitting on the primary as a vent. Block off the oil feed line on the pump. Run a straight hose from pump to oil tank vent to eliminate the Tee that is currently in place and do something with the oil return fitting at the case. Your help would be appreciated. Thank you.
