1 - 8 of 8 Posts
So I got everything for the Cyce Electric upgrade on the Gyna. It was fine until I go to plug the stator/regulator. The male plug (stator) refuses to fit inside the regulator plug. Being they're made of hard plastic, I'm not going to force it and break something. For grins I measured the outside of the stator plug and got .868 X .763. Inside of the regulator plug measures .784 X .664.
So is they're a trick to this or is it supposed to feel like cramming 10 lb of sh!t in a 5 lb bag?
Never mind. Not enough beers involved.
2 beers later I figured out I was trying to install the plug on the stator wires backward. DOH!
Deleted. You fixed it before I finished typing.
Sometimes I get a brain fart. :)
Completed that section. Now to finish wiring and put everything back together.
When I used their parts on my TRX it was triangular pins into round holes. Which made me make a phone call.
The answer was to man up and shove the connectors together. The three sided pin in the round hole makes for a tight fit and stops the pins from burning up, which is exactly what was wrong with my original setup.
Discussion Starter #7
So that's better than a square peg in a round hole?
i have a bro in law not able to plug in and twist an auto blinker bulb in...he cdnot figure it out for 10 minutes... asked me to do it... he coulnt turn it 180 deg till i showed him...we all had a laugh for years over it...but this was stupidity not a brainfart like u had
1 - 8 of 8 Posts
