1 - 8 of 8 Posts
A volt/ohm meter and a Harley Electrical Diagnostics manual are your best friends right about now.
Sent from here.
Sent from here.
Ok great. Thank you
Everything was fine until I blew the 40 amp fuse and after replacing I’m losing power somewhere. Been at it for 3 days already.
Without a wiring diagram, this is just an educated guess. But I'm thinking ign switch. It broke and sorted out momentarily as the sprinloaded bits scattered about.
So see if it has power going in, but not coming out.
I checked that. I have no power going in from harness/ connector. I found a 12v / 30amp relay that has a pos and neg wire going directly to the battery. Also just found 2 exposed wires so I guess I replace relay and go from there…?
Relay or circuit breaker? Breaker will have just two connections. If both are going to the battery, then someone has been poking and hoping while making mods to that system.
Discussion Starter · #7 ·
Yep I found a relay going between battery and wiring harness. Definitely not OEM. Going to replace relay tomorrow. Thank you
Check and verify all fuses.
Do you know what caused the 40A to open? That is not a common situation. We’re you doing something to it to cause the problem?
Sent from a handheld item of convenience
1 - 8 of 8 Posts
