Has anyone tried this map yet?
Read about it in latest Enthusiast mag. MoCo offering the map free for 07-08 bikes. Shuts down rear cylinder at a preset temp during extended idle and parading. States it is purely for rider comfort (heat) and not engine wear.
Also claims bike will be returned to stock at no cost if owner doesn't like it.
I'm on an 07 RG and noticed a good amount of heat from rear crossover pipe. I considered this normal since my right leg was directly in line with the pipe. Previous ride was an 02 Heritage with V&H BigShots which swept back well forward of my leg.
All that said, I switched to the V&H Dresser Duals about 6 mos ago because I like the open and chromed trans area look on the right side. This also completely eliminated any heat "issues".
Curious if anyone has tried it and what their thoughts are.
R/Fat
The service dept will install and un-install the map (one time each way only) for free. If you have a SERT and the appropriate software (da disk) on your laptop, you can install and un-install it all you want with any map you upload. I tried it, but didn't like it. The idle felt real strange and the smell was bad.
