I've heard from a number of sources that the HD fuel injector on the 02/03 touring models is the Chrysler Dodge Stealth fuel injector. If so, that means that they are Denso 360cc/min injectors for the non turbocharged Stealth. The direct replacement on the Stealth for the Denso 360 is the Denso 550 Part number 195500-1370.
Now the HD docs say the HD injector is 4.35gm/sec. That converts to 440s not 360s. So who is kidding who?
Can anyone actually confirm the injector part number and flow on an HD Touring 02/03 model AND the direct replacement part number for bumping the flow 50%.
If you think no ones done this yet in NA you're probably right but I don't like the stock injectors running a pulse width of 20ms at 5500RPM when they should be 12-15 max.
Forget about shimming the fuel pressure regulator.
