Here is the new info:
1. HD has now released a custom calibration cartridge for the new EFI SE103 Road King Stage I. It is rated at 92HP @5500 and nothing at 6500.
2. HD has now published the ratings for a stroked 103 EFI high output touring model - guess what? - 92 HP @ 5500 and nothing at 6500.
3. HP continues to publish the stroked 103 carbed touring TC88 at 112HP at 5500 and 118HP @ 6500 with the 45mm carb kit et.al.
Mystery where is the 20 -30 missing HP on the EFI vs Carb for the 103 - all other things being the same?
Answer:
1. The EFI Induction Module at 40mm can't compete with the 45mm flatside carb. And there is no upgrade for it.
2. The EFI injectors at 4.35gm/sec 360cc/min are maxed out with the SE EFI Tuner at a 20ms duty cycle at 5500RPM so it is impossible to get enough fuel to the motor.
Conclusion: You won't see 120HP on any 103 or larger Harley EFI motor any time soon until a 550cc/min injector makes an appearance ($75) and you still may need a fatter Induction Module (big bucks).
The good news: Anyone who looks at HD's new performance configurations posted this month will easily spot the 20-30 HP difference between the carbed and EFI 103 and ask what the @#[email protected]? is going on at 5000RPM! Why does the EFI 103 go in the dumper at 5000 while the carb pulls strong to 6500? They won't even sell them until this is solved. You can get the same from a EFI high output 1550 - and that you can feed with the stock injectors.
You better believe they are on it!!!
Dealer meeting in January!!!! Stay Tuned!
Answer:
