1 - 9 of 9 Posts
My wife has small hands which makes it difficult for her to pull the clutch in on her 883 Hugger, being that she has to pull so close to where the lever handle rocks. Her hand is to short to grab at the end of the clutch handle, where the leverage would be better. I've adjusted and lubed the cable, also tried reorienting the clutch handle on the bars.
With that said, I'm seeing two products, one for increasing leverage, where the cable connects inside the primary and the other is a different ramp design.
http://www.clutchlite.de/en_home.html
http://www.easypullclutch.com/
Looking for pros and cons on each device, from those of you that have used either or both devices, also any other products not mentioned.
I'm Paid Up...
Neither of these will change where the lever sits, they'll only make it easier to pull.
Here's what I did for my gals bike.
Remove the lever and add material to the inner side. This is the side that hits the clutch perch. (Where the lever stops fully extended). I used JB WELD. Put a piece of cardboard thru the slot where the cable runs, so you don't get that junked up. Then you can sand it smooth, and it won't be noticed, as it's almost the same color. Measure how much you want to add by pulling the lever back and having the rider see where they want it.
Would a photograph of your gals clutch help enlighten me? I'm not exactly sure I picking up on what your saying. Does this increase the leverage? Does it decrease the throw?
We have the easypull on my wifes 95 sportster. She has the same problem, and this was a good and inexpensive fix. Well worth the money.
YMMV
YMMV
Thanks, the cheapest and looks the easiest to install.
Discussion Starter #7
I used a MRC clutch for my wife when she was riding a 95 1200 sportster. Took it out of the 95 when I sold it. Put it in the 04 1200 sportster she rides now. This works very good, the original 95 clutch the wife could hardly pull it in. No problems after install the MRC.
http://www.phaedruscycle.com/
1 - 9 of 9 Posts
