I recently bought a power vision unit because I put a high flow k&n air filter on my bike and it needed tuned but after running several auto tunes and saving them and then applying them my bike is still running really hot around 320° to 340° f and no matter what I do it will not go down I'm not that knowledgeable when it comes to these tuners any help would be appreciated
Who did you buy it from and was it pre-loaded with the correct map? You can auto tune the stock map forever and it will always be lean and hot.
Look in the supplied Maps that are already in your power vision.
Go to Dynojet sight look for a map that is as close to your mods as you can find. just put in the information.
Go here
http://www.dynojet.com/PowerVision/PowerVisionMapsTunesDownloads.aspx
Depending what you put in you will come up with a list like this.
15T103a02302 Year: 2014-2015 Model: Touring - Air Cooled High Flow Air Cleaner, Jackpot 4" Slip-ons 15T103a02303 Year: 2014-2015 Model: Touring - Air Cooled High Flow Air Cleaner, Thunder Cone Slip-ons 15T103a02304 Year: 2014-2015 Model: Touring - Air Cooled High Flow Air Cleaner, Tail Gunner Slip-ons 15T103a02305 Year: 2014-2015 Model: Touring - Air Cooled High Flow Air Cleaner, Screaming Eagle slip-ons 15T103a02306 Year: 2014-2015 Model: Touring - Air Cooled High Flow Air Cleaner, V&H H.O. Slip-ons 15T103a02401 Year: 2014-2015 Model: Touring - Air Cooled High Flow Air Cleaner, Jackpot 2-1-2 head pipe Jackpot 4" mufflers 15T103a02402 Year: 2014-2015 Model: Touring - Air Cooled High Flow Air Cleaner, Jackpot 2-1-2 head pipe V&H Monster Oval Slip-ons 15T103a02403 Year: 2014-2015 Model: Touring - Air Cooled High Flow Air Cleaner, V&H 2-1 Pro Pipe 15T103a02404 Year: 2014-2015 Model: Touring - Air Cooled High Flow Air Cleaner, Jackpot 2-1 15T103a02405 Year: 2014-2015 Model: Touring - Air Cooled High Flow Air Cleaner, Rinehart True Duals 15T103a02406 Year: 2014-2015 Model: Touring - Air Cooled High Flow Air Cleaner, V&H Power Duals, H.O. Slip-ons 15T103a02407 Year: 2014-2015 Model: Touring - Air Cooled High Flow Air Cleaner, V&H Power Duals, Monster Rounds (CAT) 15T103a02408 Year: 2014-2015 Model: Touring - Air Cooled High Flow Air Cleaner, V&H Dresser Duals, H.O. Slip-ons 15T103a02409 Year: 2014-2015 Model: Touring - Air Cooled High Flow Air Cleaner, V&H Dresser Duals, Monster Round Slip-ons (CAT) 15T103a02410 - See more at: http://www.dynojet.com/PowerVision/PowerVisionMapsTunesDownloads.aspx?sel_mdl=3150&mdl=Touring&yr=2016&sel_mk=3147&sel_yr=103a&engn=103a&AEngS=103ci#sthash.hGKvtLDO.dpuf
Download the tune closest to your bike and install it. If you check you will likely find the tune already stored on your PV. by the number something like this. 15T103a02302.
Try it out then auto tune if you like.
If you had purchased it from fuel moto it would have come with a map to match your bike darn close already installed. And you would have gotten an extra year warranty free.
First
Load closest map for your bike and tune. Second check AFR value.
If AFR target is 14.6 it´s too lean. Try to adjust AFR to 13.5. engine will running cooler.
First
do you realize that you replied to a one time poster from August 2015
