Here is what I have:
2008 Nightrod Special,
Power commander 3,
Streetfighter Race Shorties Exhaust,
K&H Filter
The website has a map but with stock filter. Need one for K&H filter installed.
Thanks!! Neekster
If the only change you have made is added the K&N filter to the stock air box, the previous map still should work great for you. Give it a try and let me know.
It hesitates and decel popping increased at around 2.5 and 3.5 RPM. Also in 2nd gear lower RPM it studders. My bike is not running right at all (had everything else on it checked by 2 shops and they both said it is a map issue). The previous owner's Dyno shop set the throttle at 3%. When I set it to 0%, the bike idles rough. Feels like it is gonna stall every 15/20 seconds. It doesn't stall though.
Thanks,
Neekster
Previous owner put 3 2inch round holes in the airbox and shortened the "elephant trunk" that sticks out on the front of it.
Please give this map a try, with the air box being modified the way it is, you may need to concider having a custom map made at a tuning center. Just putting random holes in the lid and cutting the snorkel can have a pretty drastic affect on the fuel demands.
