Latest model dynojetBadTwin said:If a place advertises the Model 250i , what does that mean? Is that the latest dyno model or something?
Or doesnt it mean pigglyshi%?
Doc,hdmd88 said:The 250i has all the same bells and whistles as the 250 but the frame has changed to a wider format...with the wider format the AFR pump and the Dyno Stack up can be intergraded in the frame work, plus it has a truck universal joint connecting the drum with the eddy brake. The 250 has a flex coupling that has to be replaced now and again and its not as smooth running as the truck universal joint. The 250i also has the new softwear program winPEP 7 which is the same math as the winPEP 6 program but the 7 is windows based and lots more bells and whistles to what can be done with it as an operator.
Dang it, I have heard that somewhere before. :duh?:GRock said:The tool means nothing if the operator doesn't know how to use it. I've seen guys with homemade dynos and half ass software tune a bike to optimum in no time. And on the other hand, guys with the auto tune tuning link and all the bells and whistles that couldn't tune a go kart. Forget the equipment, check out the tech!!
Is the print problem, trying to get both HP and TQ print out for the run? 7.1.3 cured that for me. Think they fixed the Runviewer too.hdmd88 said:I teach both programs in Orlando
All of winPEP 6 and 7 programs are matched to the drum weights...there have been some screw ups in the past but today Dyno Jet has you install an utility in your computer that reads everything about your Dyno, you then fax that info to them and they cut the program wheather its 6 or 7 or The Tuning link program.
I got a winPEP 7 for the auto Dyno a while back....it showed 900 and better hp....yes mistakes do get made but as a rule all dyno drumsare different weights from the ballance factor so each program has to be cut for the drum you have.
Yes we do have the latest and greatest here even the Tuning Link. I am having a problem with winPEP 7 printing from day one up to today, I have the lattest 3.1.3. version and it still has printer problems. Personally I like the winPEP 6 program much better because the graphs are esier to read and I can alter the line thickness....the program it self is harder to use than the 7 but I and the other instructors like it better.
Did I get the shops name in the place you are having trouble with. I changed font too. No lockup, but I did know going in my printer and computer supported the font.hdmd88 said:No although this was a problem in the begining. Now we have a problem because I tried to change the fonts....it totally locks up the computer andto get out of it the whole winPEP 7 program has to be set up from scratch. I'm not the only one with this problem believe me.
If you go into the customize section and set your shop name and the font size then try to print it will say PRAMETERS INCORRECT....then it locks up.
