1 - 8 of 8 Posts
Looking for a performance map for my Power Vision. Doesn't seem to be many Power Vision maps being shared. Thanks
2011 Street Glide 103ci
SE- Air Cleaner
V&H Dresser Duals
4" Rinehart Slip ons
Power Vision
Vexedd,
Thanks for your inquiry. Currently we do have pre developed maps availible for your bike. If you make sure that your Power Vision is up to date using the update client, the tunes are already on your device. Listed below are the tune number and modifications
11T103002401 SE/AC, Rush True Duals 2" Baffles, Economy, 91-93 Octane
11T103002402 SE/AC, Rush True Duals 2" Baffles, Economy, 87-89 Octane
11T103002403 SE/AC, Rush True Duals 2" Baffles, Performance, 91-93 Octane
11T103002404 SE/AC, Rush True Duals 2" Baffles, Performance, 87-89 Octane
11T103002405 SE/AC, Rush True Duals 2.5" Baffles, Economy, 91-93 Octane
11T103002406 SE/AC, Rush True Duals 2.5" Baffles, Economy, 87-89 Octane
11T103002407 SE/AC, Rush True Duals 2.5" Baffles, Performance, 91-93 Octane
11T103002408 SE/AC, Rush True Duals 2.5" Baffles, Performance, 87-89 Octane
Please let us know if you have any other questions.
If I can jump the thread here, I'm commin fresh from the high perf sportbike side of the road and I'm looking into this Vision for my new Harley. Is buying components tricky like it is for the Japanese bikes to make everything work together, or are the Harley units easier to plan out regarding matching auto tune up with the vision and such.
Also would a 04 88" Twin cam on a touring bike have the O2 set-up stock?
thanks for letting me butt in
The Power Vision is a very simple flash and play device with the option of fine tuning a lot of different parameters. Very cool device IMO, I just wish there was a place to find different .pvt files that people have come up with for sharing.
Same here....especially for the 04 and down, since none are on the DJ site for these models.
Anyone have a stock Power Vision tune for a 2004 Touring model with an 88ci engine?
My bike is a 2004 UltraClassic with a Screamin' Eagle Stage 1 Air Cleaner and Rinehart True Duals exhaust.
The dyno tune that the previous owner had put on the bike is causing me some headaches.
Will a 2006 tune for the same setup work with my bike or will it confuse my ECU? I tried the Power Commander import, but the current tune on my bike is way rich and the PC tune clips much of the VE tables. Most of the cells on the AFR table are 14.1 all the way down to 13.1.
Thanks.
1 - 8 of 8 Posts
