Dynojet Kit clarification? - "Screamin eagle" vs. Dynojet
4K views 3 replies 3 participants last post by  OutlawTX
#1 ·
This is an email I sent to dynojet recently. I would also be very interested in others opinions. I'm a novice when it comes to carbs, I can follow instructions and do the work, but I'm no master when it comes to judging results... please comment.
I have a 2005 XL1200c. I recently bought the "Screamin' Eagle" dynojet kit for 96 and up 1200s from Harley and it has significantly different instructions than the instructions for your kit made for the 04-05 models. Here are the differences:
Your documentation for the new kit says to use a 175 main jet for aftermarket airbox and exhaust.
The "Screamin' Eagle" kit I was sold says nothing of the sort, only if you have a aftermarket airbox OR exhaust and does not even come with a 175 jet.
Your documentation for the new kit says to put the E-clip on groove #4
Their documentation says to put it on groove #3
Your kit comes with spring DSP088
Their kit comes with spring DSP009
My bike came stock with a 180 main jet and I used the 170 jet in the Screamin' Eagle kit since per the instructions it was the closest match (said to use it with either a aftermarket airbox OR exaust.)
My questions are:
Should I replace my main jet with a 175?
Should I replace the posistion of the E-clip to groove #4?
Is the difference in the springs signifigant and should I just go with the new kit?
#2 ·
The 04 and 05 xls are a bit different than the earlier xls....Seems that the dealer sold you a kit for the earlier xl......needles and emultion tubes are the same, simply go by the 04 and 05 instructions. If you don't have a 175 but do have a 180, use the 180 main jet.
The 04 and 05 s have better cams and heads flow better than the earlier xls thats why the difference in the fueling.
#4 · (Edited)
Thanks for the replies guys. Here is the response from dynojet in case anyone is interested:
if at steady cruise the bike is smooth and doesn't hesitate or surge change nothing. but if it does surge or hesitate move to groove 4 on the needle. if when you accelerate to pass a car (snapping open the throttle) and it hesitate go up to a 175/180 mainjet. but if no noticeable problem then leave it where its at.
My bike runs ok (have had the 170 main in there for about 2000 miles) but I do think I'm going to try the 180 jet and 4th notch to see if there is a performace difference.
