You usually have a simple graph with H.P. and torque on the left going up, and RPM's on the bottom going to the right. You will have two lines, one for torque, the other for H.P.
Typically, most engine make almost no power below 1500 RPM, which is about the same area the lines start (depending on the machine). The most looked at items are:
1. Peak torque and RPM achieved.
2. Peak H.P. and RPM achieved.
3. What RPM ranges the torque is near linear (usually referred to your powerband), meaning, when the torque holds a steady incline that is not drastic, until the torque begins to drop off.
