OldBoldPilot
This will probably only interest a small group of readers, but here's the data:
Bike: '06 Heritage Softail Classic
Stock engine; Stage 1; K&N air filter; Power Commander
Rush slip-ons with 2" baffles
Then changed to V&H Big Shot Longs with quiet baffles.
The dyno tune with the Rush pipes was done last March; the tune with the V&H was done last Saturday. Same tuner, same dyno.
The results were interesting. The first run showed that I had lost a fairly significant amount of horsepower with the V&H pipes compared to the Rush slip-ons with stock headers. Even the tuner was a little surprised. After a number of runs, he finally got it up to almost the Rush numbers. Here's how it came out:
HP: Rush 71.5 V&H 71.1
TQ: Rush 75.5 V&H 74.3
Pretty close. However, what's significant is that at 2600 rpm, the V&H pipes produced 66 ft-lbs of torque while the Rush produced 71 ft-lbs. So the Rush pipes felt better in the low and mid-range, which I could have told you.
The back of the V&H quiet baffles is closed, so the tuner had to drill a 5/16" hole for the probe. Made no difference in tone or volume.
I bought the BSLs for looks, and still thenk they are the best looking pipe for a Heritage Classic. But I'm thinking my next move will be to a 2:1 setup, most likely the Fat Cat with quiet baffles.
Can anyone say what a realistic expectation for a power boost would be with the D&D without any other changes? My goal is to achieve max power out of a stock engine.
OldBoldPilot
Ordered the Fat Cat
Thanks for the reply. I finally ordered a Fat Cat with quiet baffle yesterday, but because the one made specifically for the Heritage is a special order (it's a little longer than the others to clear the bags) I was told it could take up to 2 weeks to get. After all the positive comments on this board, I'm really looking forward to it.
Sounds like you're going to spend more money in pipes than upgrading the engine. The D&D should serve you well though.
Twist it, pop it, burn it
If your looking to make more power perhaps you should invest in a Stage 2. It may be more beneficial in the long run, unless of course its the look you are after as well.
keep us posted
OldBoldPilot
Discussion Starter #6
Well, since I have a buyer for the Big Shots, and plan to sell the Rush pipes as well, the net cost shouldn't be too bad.
I know you didn't mean your comment as a criticism, but here's how I see it. I'm a pretty conservative rider, and while I know I could appreciably up the performance with even small upgrades, like cams, for me the stock engine is just fine for the type of riding I do (long-distance touring--almost 17,000 miles on my '06). The engine as it is is pretty much bulletproof, and I want to keep it that way. That said, I do like to get the maximum I can out of the stock engine, and I believe the D&Ds will go a long way to helping me do that.
Others like to really boost their engine's output with some serious mods, and that's fine. I did that, too, when I was younger. Different strokes for different folks, I guess :brows:
