(hp x 5252) / rpm = :)
Just curious to see what a normal wait time is to get "tuned"....not just a map and then shoved out the door but "tuned".....
Seems that it varies based on the location/dealer/indy etc but just curious...
Incredible
This will be interesting to see the responses on this. Some people think that dyno time should be bought in hours and that is crazy. A proper tuner should be able to get you in and out in a short period of time by starting with a map that is close and then fine tuning it for your build. If the tuner is incompetent then I can see why you would end up being there for a while.
The Anti-RUB
If you mean the wait to even get in the dyno? Last I checked, the wait at Fremont Cycle Center (HD Dealer) was 2 months. But that was back in December. I have no clue what it is now.
As for the tuning itself, the same shop says they block out 4 hours for the tune, but you only pay for the time your there. So I guess it depends on how funky your build is...
Doofaluumpa
Start to finish on my fresh build, totally custom map.........3 hours.
Hellbound Train
A Stage 1 should only take a few runs, maybe an hour. A performance build will take 2.5-3 hours if you want all the performance you paid for.
If your tuner doesn't know what he is doing, he will charge you a flat rate, dump a canned map, run it once, fatten the fuel, run it again, print you a sheet, shout "next" and tell you "that's as good as it gets". If that's what your tuner is telling you, you have left HP and Torque on the table.
A flat rate tuner is looking for quantity, not quality.
