· Premium Member
Does anyone know if you can buy a saddle bag support for a Dyna (02 FXDL) that doesn't require moving the directions? I have small bags that fit between the shocks and the directional lights but can't find a support brack that doesn't require moving the lights
Ray
· Registered
Ray,
Try Drag Specialties. I bought a set for my 02 FXDL, but don't remember the model number.
I do have to admit, they were sort of a pain in the ass. I had to remove the stock turn signal spacers (which I thought looked pretty good), and install the supplied hollow studs. This required running the wires for the turn signals through the new hollow studs, which means you either cut the wires and splice them back together, or unplug (unpin) the wires and re-route them.
Good luck if you decide to go this route. Just my $.02.
· Registered
Ray
Ray,
I have bags on a wide glide and have modified the bag frame to fit into the last hole beyond the directional light.
I have a jig to do this job. This could be done if you want to send me the frame only
Andy
