G
Guest
·Hey all, I'm rigging up some automotive lamps to use as passing lamps on my 2002 FXDXT. Not using the H-D passing lamp setup because (of course ...) they don't have one that fits with the FXDXT mini-fairing.
Got it all figured out except I'm not sure which fused circuit I should draw power from. After perusing the service manual and eyeballing the load on the various circuits, I'm assuming they either just tap the accessory circuit (but whaddoo I know ... ;-) or they connect direct to the battery for power with a relay connected through the accessory circuit (i.e a lot more work ...) so they can't be turned on when the key is out.
Can anyone who has H-D or other passing lamps on a newer Dyna let me know which fuse circuit they tapped into?
Thanks!
Thanks!
