I am trying to run my wiring through my handlebars and I got the front bolt out of the gas tank and the nut at the rear but it seems that there is something still bolted on which isnt letting the tank move up at all. I just need to get to the connectors for the switchs.
I'm Paid Up...
Those are the 2 bolts. Then there is the crossover tube at bottom front, and fuel line at left side. Just prop tank up with a rolled newspaper on right side, look in with flashlight and disconnect connector, then do same on left side. This will work unless you have large hands, then get the girl to help you.
