1 - 9 of 9 Posts
I've had my 2008 EGlide Classic for a bit over three weeks :wootdnc:
I really want to slap on a set of Rineharts, will I harm the bike if I don't do any other changes, can't really afford the Power Commander and other tuning stuff right now ..what do you guys say? suggestions??
Thanks!!
:welcome: and introduce your self. going to duals will put you in need of a reflash or a dyno at least. The Y pipe acts different than a dual setup. Do your stage 1 stuff, I would stick to the Y pipe and some slipons. S&S SPOs are quiet but have a great rumble. You will need some way to richen it up, buy the best, the other stuff is just a problem and a waste of money.
Hmm
sounds like this is the direction that I want to go S&S SPOs with my
2008 EGlide Classic, if I understand this correctly I can use my stock headers with S&S SPOs and get away with out re-mapping, it this true .
Ezdaze
It's been along time coming
If you have the stock air cleaner, you are ok. You need a remap if you move more air. with a free flowing air cleaner and free flowing muffs you will need a remap.You will find out that it is worth it in smiles per gallon.
route66paul thats the info I was looking for, need to do this on the
cheap, will go to stage one when I have the coin to update the headers
and air cleaner
Ezdaze
ezdaze said:
Hmm
Ezdaze
No problem with the SPO's without mapping. Very nice rumble but still quiet. Noticable performance bump on my otherwise stock 08 RG. Did I mention that I have a set listed for sale in the classified forum here?
http://www.v-twinforum.com/forums/showthread.php?t=113695
"Jane you ignorant slut!"
I have Rush slip-ons with the 2" baffle, stock air cleaner. It's lean, would it be lean with the 1'75 or 1.5 baffles, I don't know.
How do I know it's lean? The right slip-on is starting to yellow right where it clamps on.
Just got the new SERT and will download and put on the SE air cleaner this week.
Chris
Did you notice reduced heat on the right side as a result of a better breathing pipe, or is it about the same as with stock mufflers?
I would say it's just a bit better. Hopefully it will drop after I put the Fatcat/Quiet baffle, air cleaner and & SERT combo on.
1 - 9 of 9 Posts
