I have a Daytona Twin tec and a while back I had loaded a custom map. Unfortunately my bike ran better with the stock ign. I am going to put the DTT back to it's standard down load. My question is do I just check the flash advance table option and do I leave the fixed intial timing and fixed rpm unchecked then hit upload? Anything else I need to do? I am not computer savy and the instructions are not clear to me. Thanks
correct...check flash advance tables
keep rev limit checked and set it to what you want 6000, etc.
do not check fixed initial timing and make sure that fields for rear cylinder offset and initial timing have "0" in them.
upload and now you are going with your dials.
EJK_dyna, thanks. If I uncheck the rev limit box can I set the rev limit using the dials? thanks
<< If I uncheck the rev limit box can I set the rev limit using the dials?>>
Yes, sorry. I am used to hard coding the rev limit with the laptop so the rev limit can't be mistakenly changed when fishing for the dials.
