1 - 10 of 10 Posts
I put 26G cams in my '00. It had a Stage I and Samson slip-ons. It ran great. I later put on V&H True Duals. It still ran good. I later added a DFO. The DFO helped tune out a flat spot in the throttle response.
BTW, the eBay unit you are looking at is not a Stealth model. The pic shows crimp connectors and the ad says you have to crimp it on. If I bought a DFO, I'd spend the extra bucks and get the Stealth model that requires no crimping.
2005 Road King Classic
OOla said:
Hi.
I´m putting in a set of Andrews 26 cams on my 99 FLHRCI RoadKing.
Will I need a DFO/TFI and if I do will this one work?
http://cgi.ebay.com/ebaymotors/ws/e...d=1,1&item=4612505475&sspagename=STRK:MEWA:IT
It comes without connectors (crimp on) Is it a good buy?
I have Stage1 installed (SE air kitI did the Flash)) with a set of Kerker fishtail pipes.
Ola
I just got this email. This might be a better way for you to go.
Hi Bill,
Thank you for the email. We can do that for you through the end of February
for $399.99 + free shipping in the continental US. Call us at 800-368-6217
for the special price. The part number is DS10200215. Be sure and let others
know on the forum that this price is good through February 28th 2006. Thank
you for choosing Direct Parts.
Sam
SWDONAHUE said:
If you want a DFO/TFI ,I sell them and will give you the settings,also like was said the stealth model is better
OK, I´m convinced, Stelth mode it is
I understand that I can go without one for the time being.
What kind of unit do you sell and how much is it.
Doing time, behind bars!
Deal me in here too fellas,
OOla said:
OK, I´m convinced, Stealth mode it is
For Sale - TFI Techlusion 1040 ST
How about $110 shipped? You need Paypal and I can sent it as early as Sunday..............:hmmm:
Discussion Starter · #7 ·
Now the job of changing cams is on the way. We did a dynorun first and the result were 69.1 HP, wity HEAVY popping on decel. I guess I need the DFO.
Can you ship to Sweden?
Thanks Ola
Discussion Starter · #8 ·
I got HEAVY popping on Decel on the Dyno (69Hp) Will the DFO fix that?
What do you sell?
Thanx
You've got mail.......
Thanks Ola
Check your PM's, thanks, John
Discussion Starter · #10 ·
Job is done and the Dyno says 73.2 Hp and 120Nm (89ft lb) torque
The bike is also running lean so I guess a TFI/DFO will help me
Thanks for all help
1 - 10 of 10 Posts
