Hey everybody! Just joined the forum, and thought I would seek some advice. I just bought a set of Carline T-bars for my '99 nighttrain and was wondering if I should order harness extensions or if I'll have enough slack as is. The bars have 8" risers and 9" of pullback. I took my dash off my tank and can see the connectors. It looks like I have a little slack to play with, but not much. Anybody have any experience with this? thanks in advance.
You should have plenty of wire to work with.
There is more slack then you think:xhere:
I'm Paid Up...
No extensions arent cheap, but you can splice in the required amount of wire that you'll need, if you come up short. It's very easy. One spool will do, any color, as you'll put the splice in the center, so each end WILL be the same color code.
