What can a dyno-tunner do to remove the torque curve from my bassani pipes, Can it be done with my build.? To Anyone with experiance with road rage by Bassani.
If you actually look at the time stamps for his dyno runs the "awful AF ratio" is the baseline run. The final run has a nice AF and is spot on in the area of the torque drop.He can fix that awful air/fuel ratio between 2-4K rpms.
If there is more than one baffle choice which one do you have?
Only one I know of, pull yours and check the packing, mine was blown out and cheap quality, I repacked with some better quality FMF stuff I use in my 4 stroke dirt bikes.nvsteve, thankyou for the reply. I dont think there is a baffle other than bassani tappered and luvoured 2.5 " that I have installed. I kinda think I would like to try a 2" baffle.
jasilva, ditto. I get to take it back for the 1000 checkup and oil change and final dyno, the map I have now is the preliminary break in map.history: new pistons and cylinders just 600 miles ago.
JC Rocks.:clap:
Do you know if there are 2 baffle sizes for the road rage 2-1?
:thumbsup::thumbsup::thumbsup:JC Rocks.:clap:
