Doofaluumpa
USE AT YOUR OWN RISK!
This map is used in conjunction with the following:
1550 STG 2 DOWNLOAD CART#32083-01B CAL#33263-05B
The rest of the build is in my signature, good luck.
:thumbsup:
Thanks.I got the same build, but mine is stage 1, dont know if that makes a difference,I will give it a try. if it doesn't work, i going to the local dyno shop. Maybe i can save a couple hundred bucks on dyno time. Of coarse i squeek a little when i walk. I will let u know how it works out. Londogs
Doofaluumpa
Every bike is different, even those with the same components. Hopefully it'll help you get some good break in miles, but there is no replacement for a good tune. It might help you with how long it's on the Dyno though. We all squeek when we walk, but you put the $$$ into the build this far, don't cheat on one of the most important parts.............tuning. Good Luck!
