Does anyone know if a 2004 Deuce rear wheel will fit on a 2005 Dyna Wide Glide?. I've got an opportunity to get a set of mag wheels off a 2004 Deuce ( sold as a pair). I know the front will fit but have no idea about the rear.
Punch It!
I run a 2003 Deuce rim on a 2003 Wide Glide. Fit fine with the Wide Glide spacers. I used the Deuce pulley and rotor but either will work. You may need to grind down the back of the brake caliper so it can clear the rim. I think this problem is only on the stock rim as it has a thick rim edge. Either way the grinding is not a problem i used a 4.5 inch angle grinder with a pipeliner wheel. You do need to grind quite a bit, but it is not visible from the side. I run a 170/60-17 Metzler 880 and love it...............Ward
Seasonably Uncool
I saw a 2004 Low Rider at the Harley Davidson Factory in Frankfurt and it had the Deuce Wheel with the stock Dunlop 160 on it. It looked awesome!
Don´t know how involved the install ist though.
BTW, they also had a 2004 Sporty with the same wheel, and it too looked great.
Cya
Sponk
