I'm about to change out the sprocket on the rear wheel of my Deuce. Looking at the service manual, they specify using Loctite Red 262 upon reassembly. Spoke with my dealer to see what they do, and they say that they use Loctite Blue when they replace the chrome bolts so it won't bond so tight and then there's less a chance of striping out the threads the next time someone takes the bolts out. Anyway, I'm assuming that Loctite Red was used at the factory and am a bit concerned what it takes to remove the bolts without any chance of striping out the alloy wheel. Anyone have any comments/experience in removing the sprocket bolts on the rear wheel of the deuce. Did you use heat, etc.?
(Forgot to mention that the service manual specifies Red 262, but the instructions that come with the chrome bolts specifies Blue 243, which according to the Loctite web site doesn't exist. I could only find Blue 242...Argh!)
