So I go to a local dealer (they have a decent rep) and the service guy says, "sure we can put in your SE203/Andrews 21 and because you have a Dobeck TFI box you won't need a flash, that will save you about $200"
So what do you think will just the pots adjustment on the TFI be enough??? my bike is a 06 FLHT, 07 mufflers and K&N air filter, the cam will be the only addition. Comments.....CSM-H
Even stock bikes could use a custom tune. can you get away with it? sure, but you could be leaving as much as 10 hp.
Put in a better cam, boost the c/r, port the heads, get a custom tune. That will give you a completely different bike
The 21 should do better with the TFI because of less overlap and duration. I would not hesitate. IF you have it use it. Dont be afraid of adding a cam like the 21 or 26. The SE204 may be OK also but would think the 21 or 26 would be better with a TFI.
