Pulled into drive and bike quit. Lights, horn work. Turn signals don't and nothing when I hit the start button. 04 ultra classic. suspect a fuse but not sure. Any help? Thanks
First check battery, i know it sounds stupid but it's always best.
2nd check voltage to circuit breakers
3rd check voltage at ignition switch
4th chack voltage at coil
Give the earth wire a good pull to make sure it had not broken
At least what you have will be relativley easy to find. It's the bloody intermitant ones that are hard to find
That translates as "Give the ground wire........................" in American English.
