1161 - 1169 of 1169 Posts
Thanks! I've had a crazy life change the past few years and haven't been here at all. Still have my bike and ride all I can but have become a father and picked up with an old car hobby but the TCFI has been great for me.
Can anyone help me out? It is no longer available from DTT and I lost my CD. Chris has offered to sell me the newer version TCFI at a super deal but I cannot pull the trigger for a few weeks. I'd really like to pull a little timing but I need to see the log to know where.
Any help would be SUPER APPRECIATED!!!
Bump! Anyone else think they have a copy of the older 10.0 file?
Friday bump!
Still looking for an older copy of the log software. 10.0, circa 2006/7!
Thanks.
I have the setup program for ver 10.0. I dont know how to get it to you tho. pm me.
Is anybody still using this thread ? I am running a DTT and have it dialed in - good power & gas mileage - It took some time to get it there- bad sensors - EC Jim
I am running DTT TCFI gen 4 on my 126".
The first part was a bit frustrating learning the system and getting used to things, but once I learned how to use the system, it has been great. I've had good support from Dan Thayer whee I purchased the system, which has helped lots.
I know my way around the system good now. It took only a few rides to get it dialed in and she purrs like a kitten now.
The key is to mount the o2 sensors 2" off the heads so you don't get any reversion. Also a pipe with a baffle is necessary, open pipes with no baffle don't work well for the system or a harley in general.
I started with the 95ci map, the timing has been great with that map, dyno verified.
I made 164rwhp and that was with just road tuning it. I out it on the dyno to play with the timing but it was good where it was set.
I like how you can monitor everything real time and check out logged data to see how things are running.
You must have a really good understand of how efi works to be successful with this ECM.
Still using the DTT system on my 07 Fatboy. Runs well except for the roll on pinging that I get at times. I've messed with the timing table without much luck, maybe I need to just plug in the 95ci default table and start from there.
Otherwise, it cruises nice and I have had very good luck so far.
