1 - 16 of 16 Posts
Ok guys so I’ve done the big bore kit on my 88” twin cam and installed new S&S crank boosting it up to 107“ . Runs like bat out of hell too. We ported the heads, new big bore kit, new S&S camplate and oil pump, and pushrods, fueling race lifters, T-Mann 590G gear drive cam. (starte$ with woods tw8g). So T-Mann 590 gear drive cam, hpi 55mm throttle body, scorpion clutch, new compensator,sprockets,chain, just installed 6 speed bolt in conversion kit, . S&S roller rockers, rocker lockers. So we did the build and could not get rid of top end noise With the woods tw8g cam so switched to the t-Mann 590G. This did quiet it down. Then 8 switched from S&S premium lifters to fueling race lifters. That helped some. Regardless I have done every test, checked for clearance nothing is hitting no where. I can not figure this out. I know they all make noise but not like this. It sounds like something’s wrong. I’ve had 5 or 6 bikes in last 10 or so years and harleys custom choppers whatever never have I had this noise. It sounds lik3 it’s hitting but it’s not. I’ve ch3cked 3 times. Any suggestions would be great. I’ve done all the normal test. 3 and 4 times. I also have really high compression. I’m pumping about 208PSI per jug. Doing a leak down test I had 5% up front and 8% in the back.
thanks
Brian
2006 Electra glide.
That's 14.4 to one compression ratio. None of the octane charts I could find go over 12 to one. What kind of gas are you burning? 110 octane is 12 to one.
They say with the cams I have and 208psi each jug is at about 10;1;1 compression I’m running best gas I can get. I used thundermax and adjusted my throttle position vs RPm and was able to get it to stop pinging. I also found that as the engine expanded the outer part of my crankshaft gear was ever so slightly hitting the cam cover and causing a heck of racket. Then we also used some fueling race lifters and she’s sounding great now.
208 divided by 14.4 atmospheric pressure is 14:4 compression ratio. Gasoline octane charts end at 12:1 which requires 110 octane gas.
I think there is a mis-communication going on here, one person is talking about static (mechanical) compression, and the other is talking about running compression. Octane requirements come from static compression.
208 PSI is at the lower end of diesel compression ratio. If it was measured with a gauge in a shop then 208 is excessive. What is the measured compression?
im sure most of you know this, but,, the mechanical compression is a fixed number based on swept volume divided by chamber volume..
the running compression is greatly affected by the cam shaft/s,,, ive seen 10.2 mechanical turn out 250psi cranking,,, due to using a tiny motor torque cam in a 10.2-1 117"... leading to hard to impossible starting,, eating starters and batteries, losing so many teeth on the ring gear it needs a dentist, compensator failures,,, and so on...detonation with any throttle input... cant be heard over the fishtails, and the genius's solution? add comp releases,, what genius
Discussion Starter #12
I just went off what I was instructed. Here’s a photo from the recommendation for the cam chose. It’s running good now. Sounds great, runs very strong so I’m pretty happy. I may have said something wrong or something. I don’t know But it worked out and that what counts right
Of course then think about power adders: Nitrous Oxide, super chargers, turbo chargers. We take those 2.0 Ectotec motors, put them on alcohol, add a 104mm turbo, set it for 60 psi of boost, and get over 1500 hp. out of them.
00 Road King, 00 Ultra, 98 Fatboy, 08 Goldwing
thanks
Brian
2006 Electra glide.
thanks
Brian
2006 Electra glide.
thanks
Brian
2006 Electra glide.
I have a similar set up with my 00 Road King. 106", .585G cams and complete S&S valve train. I have tried many things over the years and have come to the conclusion that it is going to be noisy. I also have a 00 Ultra(95") with 510G cams and S&S valve train. It is a little noisy also. Both bikes run great and I have 69K and 105K on them. I have just learned to live with it. If you find a way to make the quiet, let us know. Sorry I have no advice to offer.
Discussion Starter #16
Thank you so much. I’ve double triple and quadrupole checked and I did find I was hitting a little on camplate cover and when I grinded that down it quieted down a lot. I also switched back to regular oil instead of synthetic and that made a huge difference. My bike just don’t care fir synthetic. I’m in same boat now. She runs great. Turn up the stereo and let’s roll.
1 - 16 of 16 Posts
