olly said:
Syclone, CR 9.4/9.5:1 is similar to what I have calculated. What are you thoughts on a cam to match this CR. Heads are good for about 550" lift. Dependant on your suggestions for cam what additional depth clearance pockets would I need to put in to my std CVO flat top pistons, if any ?. Can you suggest a good retailer to contact for the part you suggest.
For an andrews cam..for your application..I like the tw50g better than the 44g because it's got a little more lift at .510 and more duration ..It will come on a little later, but a 103 motor in itself at 9.5:1 will already have more low end grunt than a 88 or 95.
The red shift 557 reminds me of the wood tw6gh cam...but with lower lift at .557 its ramp shape means it will be much quieter. It's a bolt in high torque cam that will work anywhere from about 9.0-9.7:1 It may require some case clearancing though. Tdc lifts should not be of concern with these cams.
those would be my choices right now....I say MY choices because one of my bikes is an 05 CVO E-glide ...that I'm loooking for a bolt in cam to simply rid myself of the tensioners.
I'm going to hold off for a while because first..It's snow season for me...and both Zippers and Freedom cycles are curently developing bolt in cams for the CVO motors that will offer modest performance gains...
As a point of reference...my stock CVO 103 with slipons.,a/c and race tuner made 101/103..on a dj250. I would think you should be able to achieve low to mid teens in torque with lots of area under the curve. Hp will be what it will be.
for a supplier...directparts.com , Jp Cycles, Zippers...and check with HDWRENCH on this forum..he's a great guy and can also give you some direction and well as parts sources.
