1 - 10 of 10 Posts
Bike Driver
My question is if the dyno jet kit is available for SE CV44 carb..???
I don't seem to find any kit in the SE catalog stating it is
for CV44,
the only ones I've seen is for the original CV ...
So if anyone has a part # for the right kit I would appreciate it !
And is it worth the money and effort to get it ...?
For great (not god) dyno tuning and performance.
What could one expect using it compared to ordinary jetting..?
zeb
build in progress
98" 10.26:1
ported heads
TW6HG
CV44
DTT
Pro pipe
etc.
for CV44,
zeb
build in progress
98" 10.26:1
ported heads
TW6HG
CV44
DTT
Pro pipe
etc.
Lazybone:RTFB: :D
http://www.dynojet.com/pdf/8733.pdf, yes there is one, but it's the Thunderslide version
The SE CV44 Race tuner kit is much cheaper and you gonna look up that # yourself, don't ya'?#[email protected]
0043--Licensed to Doof!
I got one I'm not using anymore, you want it? It's got most all the jets, drill bits. You would have to get the softer spring if you want to use that instead of the stock spring. I could do an inventory of it and let you know exactly whats in the box. Email me at [email protected] and I'll send you the list. Of course I'm in the USA and you're on the other side of the Atlantic. What would shipping cost? HHmmmm.........
Your call.
Bike Driver
ViennaHog said:
Lazybone:RTFB: :D
Thanks Vienna, It's soooo nize to be laaaazy :D :D :D
I got the #27419-99 for the race tuner kit allready :harhar:
Seriously, I didn't know that the only kit for the 44mm
was the thunderslide, and I don't want that one.
So thanks for the kind offer Geezer but I decline.
I'll stick with the Race tuner kit.
:banana:
The dyno jet kit will not work in the 44mm carb...the needle in the 44mm is much longer than the 40mm carb, the dyno jet kit is for the 40mm only.
Bike Driver
Discussion Starter #6
Thanks for the explanation Doc !
Do you have any thoughts of the 44mm Thunderslide kit ?
There is no thunder slide kit for the 44mm carb, the 44mm takes the HD race tuner kit that has 4 needles, selection of pilot jets, a selection of main jets and a lighter spring along with a bowl gasket and four float bowl screws.
Bike Driver
Discussion Starter #8
Thanks, but now I'm getting a bit puzzled :blink:
:D
:D
The Thunder Slide Kit has a plastic slide in it and it cost around $150.00.
The 44mm C/V carb is a Screamin'Eagle carb...the 40mm is the stock carb and a Thunder slide will fit in it but I wouldn't go with it, the Dyno Jet kit is for the stock 40mm and it works fine.
The 44mm Screamin'Eagle carb needs the Screamin'Eagle Race Tuner Jet Kit that comes with the four needles, selection of main jets etc.
Bike Driver
Discussion Starter #10
I'm not puzzled any more :banana: , well, not more than usually anyway
Thanks a lot doc !:cheers:
where would we be without you ...
1 - 10 of 10 Posts
