1 - 20 of 30 Posts
Bowhntr
Folks,
I'm about to drop some $$$$ on a custom paint job for the deuce (I'll be keeping my original tins). I'm considering the following 3 vendors:
1) Attitude Custom Painting
2) Vividdragon.com
3) Jimmurone.com
Can anyone give me some idea if they used any of these vendors and if they were satisfied with the results.
Thanks!
ST
did u chose one? i'm waiting for estimates from attitude and vivid
I can't say enough good things about Attitude Custom Painting. Check out my bike pictures here.
http://www.v-twinforum.com/forums/showthread.php?t=112488
Scott and Jodi are absolutely terrific to work with and really know what customer service is about. I'm 110% satisfied with the job they did for me!
Another...
This is a bit akward...recommending myself....but if you'd care to talk paint I'm all ears. You can check out my work on the web - www.kustomflames.com and I will offer any memeber of this forum a cool $200 off the price of a paint job...
And, if I might add, the other painters in question are both very talented.
Thanks all!
Pat
Here for the education!
painters
I'm not trying to be a jerk but i have seen all of these vendors you are talking about and none of them come close to the quality i have gotten from j e illusions. They are simply the best in my opinion. www.jeillusions.com
For sure! Josh is one of the best! Not exactly an apples to apples comparison though...his work differs a bit and he gets top dollar - probably 25%-50% more than the others in question. But again, top-notch, show-winning quality work.
Bowhntr
Discussion Starter #8
Thank you all for your comments. Sorry I didn't check back for a while, cause I guess this question has been asked so many times (I'm a Harley newbie) it took a while for anyone to respond. Anyway, I did order from Attitude Custom Paint in Fla., and my tins should be in by haloween.
Regards,
Screwtop
on-line bike painters
I've had one bike done by Attitude, and two by Jim Munroe (he's in RI)
Both are good, I (JMO) would give the slight edge to Jim. But he's a one man operation versus more of a quantity operation like Attitude. Jim's job seemed a little more "custom."
Nothing against Scott Farrell tho...did a nice job for me as well.
Again JMHO, YMMV
ace57
'06 FLHRS "mattie"
You might want to go with one that actually bakes on the paint, some say between each coat. This will give you a harder finish and shouldn't show the tiny polish marks that softer paint does.
Josh at JE Illusions will always get my vote and my business from now on. Best paint of seen in a long time. Absolute perfect and GREAT CUSTOMER SERVICE!
I went with Vivid Dragon. Shadd is a top notch guy returns all calls and usually picks up the phone himself. Very accomodating and works with your input throughout the process sends pics to confirm the layout and all. Uses all new oe sheetmetal not ebay sale pieces that others use and paint over. Only time will tell, should have within the next couple weeks. Seems this is their busy season.
Technically...............if it is a multi stage (basecoat clearcoat system) You have NO need (or shouldn't) bake the bases...as far as clears go, you don't always need to bake them. Some clears hardness or ability to show tiny sanding or polishing scratches are dependent on quality of product or technique used to color sand & polish (ie how many steps of grit used or how many compounds used). There is definite science used in the procedure of color sanding & polishing new clear coats. It even goes to the surface/clears' temperature you get the surface to while buffing...too little it wont get out the scratches, too hot it adds more. This applies to "custom paint" products...perhaps not to production or OEM finishes.
Regards,
Screwtop
Let's see some pictures!
Trust me when I tell you that you got the best qaulity job out there from Attitude. I've seen so many custom paint jobs around that can't come close to the paint job that Scott did on my bike.
I too have decided to go the custom paint route. I have it narrowed down to Airea 5150 or JEIllusions. Does anyone have any input on either company?
Ironbutt
Another vote for Scott at Attitude Custom. He painted the tins on my Heritage 3 years ago and the quality is the best i've ever seen. You'll also get excellent customer service from Attitude. Everywhere i go people ask who did the paint.
my stuff is going to kustom flames this coming weekend, I will give a heads up on the status as it moves along.
1 - 20 of 30 Posts
