Hello Dare,
Im searching for a moment, did you purchase the frame & the frt end from the same supplier? If not
Yeah I purchased them from the same supplier, DemonsCycle, but not straight from the manufacturer. The frame MSO says
Straight Up Choppers and the Forks are
Ultima 58mm Inverted 3° 4 over (these are close to what I have). I used the little
RB Racing calculator and if I did everything right it's 5.25 of trail.
I'm pretty sure the forks will work on the frame cause the rollers on Demons and StraighUpChoppers have the same forks.
your going to have to contact the frame builder & let them in on what your planning on doing & the direction of the build. If for
Yeah that was the next step, see how Demons handled theirs and then contact StraightUp. Harry over at Demons has been great in responding in the past.
Your going to have to mic/measure the inside diameter of the frame neck where the race seats & measure the portion of the new race where it seats into the neck. It should be a tolerance fit so it cannot rotate once it is pressed into the neck.
I started doing that when I thought about using those fork cups for the frame. It's 7 1/8 on the neck and between the trees is 7 5/8. I don't have depth micrometer but the digital says the inside dimension on the neck is 1 31/32. The cups have an outside dimension of 2 15/64 so I think they can be taken down so they slip into the neck. I just need to get a more accurate depth measurement than my trusty Stanley tape measure
. My machinist friend might have other thoughts.
The issue is height since I only have about 1/2 to play with. The top cup has a height of 3/4 from where it would normally sit on a standard frame neck to bearing seal washer. The bottom cup is much taller 59/64.
Scratch all that, I just measured the inside diameter of the cups and they're 1 31/32 so I might be able to use standard races press them into place and use the bearings and seals from these cups. Then it's just a matter of spacers.
What do you think?
As for race height I have seen before where the races are taller & require a longer stem to get you through the triple trees & lock-nut. Onced you are certain its ready for assembly the races should be seated/pressed in with loctite applied to the mating surfaces.
Good to know, thanks.
I hope this helps you out, good luck with the build.
Keep us posted
Dare
I will...
Thanks for the reply and your insights...
Jw
