On the new bikes the cruise control has a self diagnostic mode you enter with the ignition switch and set/resume switch and it flashes the codes with the cruise light. Some codes can only be read with the scanalizer, but it is a good initial test.
If the system has been initialized several times so as to eliminate a tight cruise cable, the only thing you can do on your own is to remove the speed sensor on top of the gearbox and clean the metal shavings off it, and see if it helps.
Generally the cause for surging is either a intermittent speed signal, a defective speedo (intermittent signal from speedo to CC module), wiring between speedo and CC module or a defective CC module.
It would be reasonable to assume by your description that the engine runs just fine when attempting to maintain the same steady speed manually. Is this the case?
If not, surging due to lean running MAY be much more noticeable when using CC, due to the natural tendency of the rider to compensate with the throttle.
