1 - 15 of 15 Posts
Hi All,
I am kind of new to this forum and also new to the Harley (have had it for a few years). While starting up the bike recently I noticed some odd sound and found that the header pipe is cracked near the engine block on the right (rear).
Went to the dealership and they want to charge me $470 for the pipe and about $600 for labor. They said I should be able to do it myself if I wanted save some $$.
The question I have is can this be welded or any place to get after market or used pipes. Should I use this opportunity to change from stock to some other pipes?
Please suggest.
it can be welded,,,, most crack up closer to the cylinder at the joint...
start saving for new exhaust,, or a replacement for that pipe..
they arent hard to change as long as the stud nuts arent seized. I use a 6 point semi deep in 1/4" drive,,,
Thanks all. Took off the pipes, as suggested it took me about 45 mins (first timer). Have given to a local welding shop ($60). Hopefully he does a good job and I should be riding again in a couple days.
Thanks for your advice.
Also, when reassembling line everything up before tightening anything. Don't pull parts together with the fasteners.
Sent from my coal burning bag phone using Tapatalk
Discussion Starter #10
Done with the repair. Also checked the mounts and those looked to be good.
Initially was seeing some smoke at the joints and was worried, but then realized that I had used WD40 during reassembly and it was the oil burning out.
Ran the engine for about 10 minutes and everything looked good.
Thanks all for your suggestions.
assemble everything loosely,,, start at the front and work your way back when tightaning...
exhaust shops will usually weld them up for $10,, or no charge for future reference..
Wow! Terry, I don't know anybody that will do something for $10 anymore. You must have some good muffler shops around you.
Check with the custom pipe installers at events. They will have a big pile of take offs. I gave $20 for one at Sturgis.
Hi All,
Please suggest. View attachment 263252 View attachment 263253
263295
I have an S&S header pipe, with SPO mufflers. I like it! You can run different mufflers, but I believe they are 2.5” not 3” on some mufflers
1 - 15 of 15 Posts
