Continued problem with 06' Ultra Classic
5.2K views 9 replies 6 participants last post by  Captainkrusty
#1 ·
I tried posting this in the electrical section but it didn't get any bites so I thought I would try it here.
I have a 2006 Ultra Classic and I am having problems with the running lights. The fuse that powers this entire circuit is the "lights" fuse and is 15 amp. I noticed the front and rear running lights (tour pack etc) were out and replaced the fuse. It lasted a couple of rides and blew again. I tried replacing it and everytime I turned the ignition switch on, it blew the fuse. I isolated the front and rear light assemblies and it still poped the fuse.
Took it 250 miles to the closest Harley Dealership and they could not get it to duplicate the problem. The fuse did not blow at all and they had it for 2 weeks starting and riding it often. I rode it home and and on the second ride, the fuse went again. This is frustrating and isn't real safe riding with no rear running lights. Any ideas or direction would be appreciated.
Thanks, Tom
#2 ·
Dead short if the fuse blows when you turn on the ignition. Buddy has a SG that did the same thing and we traced it to the mounting bracket in the inner fairing that was broken and one end of it was pinching the wiring harness. I know it's a shot in the dark, but have a look there as those brackets seem to break often. Since you isolated the front and rear lights from the switch and the problem never went away, the short should be between the switch and the power source. Check under the fairing.
#5 ·
Intermittent problems can be a real challenge. I've had switches go bad. If you've had the controls off, check for a pinched wire there. Like High Torque said, put a pot of coffee on, isolate as much of the circut as you can and be patent. It'll show eventually.
#8 ·
Two screws on the inner fairing, three screws at the windshield.
Remove the passing light bar first.
Best to have two sets of hands helping so the fairing doesn't drop on the fender..
Put a blanket or such on the fender first for protection.
After you do it a few times, it becomes easy.
If it would blow as soon as you turned on the power, that would make it easier to trouble-shoot.
P&A Fuse?
When disconnecting items, make a list of what you did because it'll get confusing after a while.
I had the same problem. Blowing fuses in the driveway was the best way to trouble-shoot.
As I disconnected items, I tagged them so I knew where they went.
My problem was a fine strand of wire where I had been working (newest item added).
Now I know where everything is going under the seat and inside the fairing.
Good luck and have a bunch of 15 amp fuses with you.
